Forty4
Just been back to a job that I upgraded the DB in and water bonding in November to find the plumber that's fitted a new boiler has cut my bonding to the water main. Now I've got to run the whole lot again FFS.
Discuss Silly plumbers!!! in the UK Electrical Forum area at ElectriciansForums.net
I reckon that is you Biff, it is a seaside town thats for sure pmsl
the pier says Clacton......
i'd use a non-insulated butt crimp and cover with a bit of gn/y heat shrink. i'd probably forget to slide the h/s on first and have to cut and re-crimp, thought.
...Know what yer mean...i do it all the time,put me crash-helmet on,and realise i've forgot me polo-neck jumper :conehead:not nearly as many times as i've wired up a flex and lighting click plug to realise i've not slid the domed cover on first....
im a clutz.
through crimps are made of copperbecause he crimps then solders, in that case it is a waste of solder.
if i crimp a cable they are tight together then solder to hold it together.
much better readings than using a steel through crimp
the solder just holds it together and your not moving it when the solder cools
Reply to Silly plumbers!!! in the UK Electrical Forum area at ElectriciansForums.net
