U
Unswitched
Hi Guys,
How do you know what size of earth wire to use from the bango to earth terminal in a DB, when using say:
25mm 4-core swa sub main feeding a DB. (L1, l2 l3 and neutral, armour used as cpc).
I would gland, with a bango and choose a size half of the phase size, so 16mm earth lead i would use. Is this ok, or OTT!?
so if 4mm2 armoured is used, I would use a fly lead of 2.5mm earth? Cant be wrong can it?
Cheers guys
Cheers guys
