Sky plus to nine positions. | on ElectriciansForums
Discuss Sky plus to nine positions. in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Lou7
Is this possible and what hardware is needed ? I'm installing in a new build and want to run the cables in.
you need a quattro LNB at the dish, 4 coax back to a central point. If you want to allow for sky plus at all points you need two satellite points at each position so you would need a satellite multiswitch with at least 18 outputs. Wire back 2 cables from each point to the multiswitch position. Also consider if there is going to be an aerial for freeview, if so allow another coax at each tv point back to a central point and install a tv splitter unit also.
If you use a multi switch you will often find they allow for dual sky feeds, terrestrial TV and fm/dab inputs on one unit, you can then run all of this down two cables too each TV point where you can have a quad plate that will give you 4 desperate outputs for satellite, TV and radio
I've got a similar situation got 6 sky plus points, I've run two shotgun coaxs to dish position then a single shotgun to each point plus two cat5 so all i need is to place the multiswitch with in that ?
Reply to Sky plus to nine positions. in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
I guess you don’t want to miss those little mermaid episodes 🤣
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
