Small consumer units!!! | on ElectriciansForums
Discuss Small consumer units!!! in the Australia area at ElectriciansForums.net
Danielwareham
Trying to locate a consumser unit under 170mm in height. Needs to be a dual/split board with space for 5 circuits.
Dan
When I was looking for a small consumer unit I ended up with one from Doepke UK Ltd, and I used their IP55 enclosure because it was their smallest one, even though this was an indoor installation. Have a look, but I'm not sure they were as small as you're looking for...
if it's only 5 ccts., why not go for a 6way board with RCBOs. ?
When I did my Doepke board mentioned above, I found that the low height consumer unit did not have the headroom to accommodate RCBOs, so I ended up using two standard RCDs and MCBs on a split board even though there were only three (I think) circuits overall!
Reply to Small consumer units!!! in the Australia area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
