Thinking of going the following & wondering if there is any reason why I shouldn't
I live in a UK House with the Lighting wired as loop in/out at ceiling rose & then a twin and earth taking a permanent line to switches & bringing a switch-live back (over the blue cable - marked with brown tape)
Current Setup In Ceiling Rose
Block 1 = Neutral from IN, OUT & Light Fixture
Block 2 = Line from IN OUT & Switch
Block 3 = "Neutral - marked with brown" from Switch & Line from & Light Fixture
Planned setup
Block 1 = Neutral from IN, OUT & WAGO1
WAGO 1 = Link to Block 1, Neutral from Smart Light Fixture & Smart Switch (Remove brown tape)
Block 2 = Line from IN OUT & WAGO2
WAGO 2 = Link to Block 2, Line from Smart Light Fixture & Smart Switch
Block 3 = Empty
This should give permanent power to Smart Light Fixture & Smart Switch, allowing me to use IFTT so that when Light Switch is toggled it will toggle light socket,
Is there any reason why this shouldn't be done, as long as I leave everything labeled & info by fuse board of which rooms are wired in this unusually way?
For clarity - the smart switch will not have anything connected on the load side, just a permanent power source.
Planned setup
Block 3 = Empty
- TL;DR
- IFTT Smart Light, Old House, No Extra Wires
