Smart switch wiring issues | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss Smart switch wiring issues in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Sean
Pembrokeshire
Hi all looking for advice in solving a problem I have?.. I have installed a 3 gang WiFi smart switch. 2 of the switchs are working as they should. Wiring I have.. Black/red/earth x2..red/earth x1. How its working.. Earth's to back plate together.. Single red to L. 2 blacks to N. Other reds to L 1 & L 2..these are working fine... 3..empty...how do I get L 3 to work?.. Is there a loop way?.. Any advice would be great thanks..
[ElectriciansForums.net] Smart switch wiring issues
the 3rd switch will not do anything because there's no cable coming out of L1.
No I'm not sure they are neutrals but 2 switchs work.. I did try moving black wires. One left in N. Other to L1.. This left no power one way. And made no difference the other..
you only have 2 switches in the old configuration, 1 of which is 2 way. why do you need a 3rd switch?
Yes but other switch doesn't do anything now..
When you say it doesn't do anything now is that because of fitting the new switch. Bottom line is you need someone on site to verify what wire does what, sometimes we can say for certain but not in your case.
I'm confused by this post.
As @telectrix has stated in post #11. The existing config only has 2 switches.
As far as I can tell from your pictures, you have 2 one way switched lights (one of which is in the next patress -fed from the back of the other light switch) and 1 two way switched light(s). It looks to me like there are is no neutral at that switch. I believe you may need a neutral for the switch to work. The two way light will need to be fixed so the other switch becomes redundant and the spare core sleeved g/y and connected to earth.
I am only guessing though and I couldn't tell you for sure without actually being at the property.
My advice would be to call in an electrician who can advise you further.
Reply to Smart switch wiring issues in the Electricians Jobs area at ElectriciansForums.net
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
brilliant thanks for your support. Lee
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
