Smoke coming from electric meter/fuse box area | Page 7 | on ElectriciansForums
Discuss Smoke coming from electric meter/fuse box area in the UK Electrical Forum area at ElectriciansForums.net
A14n
Norwich
Hi just a question, this morning I noticed a 2 gang socket had no power to it, went to check the fuse box/electric meter in the cupboard... and there was a lot of smoke coming out from somewhere? Its not smoking any more. The 2 way gang socket is completely dead. All other outlets seem fine and not affected.
What would be the problem? Is this an expensive job, still waiting to here back from an electrician.
Rewiring may be required if cables are damaged - which as @telectrix says - testing and inspection should show. You know of one fault and that may need some cable to fix, but that doesn't mean it's all unserviceable. Have you checked these guys are registered to do electrical work on domestic properties?
Competent Persons Register | Home - http://www.competentperson.co.uk/
Make that 3 faults known about. 2 dead sockets & the landing light circuit (Only 24v on circuit).
Reply to Smoke coming from electric meter/fuse box area in the UK Electrical Forum area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
