Smoke detector help please | Page 7 | on ElectriciansForums
Guest viewing is limited
Discuss Smoke detector help please in the UK Electrical Forum area at ElectriciansForums.net
M
mungo9
I have recently completed my first job and it was an extension to my Uncles house. i haven't qualified yet but the job went well and everything works, although i have 1 issue. Due to my lack of experience where my uncle was trying to save money on the job he said he didn't want smoke detectors wired in and would buy them separately, obviously i normally wouldn't say thats okay. However now the job has ended and the Building inspector is coming round soon, i realise to be safe and make sure everything passed i should have just put them in. I still need to choose the battery powered smoke and heat detectors that will pass.
Can anyone tell me what battery powered smoke dectectors i should get? and if they comply with the regs.
It wouldn't if the smoke alarms are on the lighting circuit. No circuit other than the lighting circuit would be affected.
And as said there's no reason particularly why it need affect the lights on the lighting circuit (depending on the exact nature of the work being carried out).
Like replacing a damaged cable or broken detector base.....?
Nor is a socket which is also mentioned. I am not saying for one minute I am right, but its out there and its good to know what people say.
No need to reply in a derogatory term when I was merely asking a question
see you answered your own question, completely wrong :D
Then that would be done by a professional, and would not be deemed as maintenance or service....but repair installation.
Everyone seems to bend and twist the regs.....Simlec, has pointed out document B, and has some valid points, has I have pointed out the regs, as any reg, you can twist it how you wish, but when in doubt, contact the governing body, and request info......now I have done the homework for you.
And it is confirmed, separate isolation is not required, take it or leave it.
Reply to Smoke detector help please in the UK Electrical Forum area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
Recommended Sponsor News
Hi everyone,
