So with the all steel consumer units on the way your conversation goes something like | Page 3 | on ElectriciansForums
Discuss So with the all steel consumer units on the way your conversation goes something like in the UK Electrical Forum area at ElectriciansForums.net
B
baldsparkies
Customer
Hi,
You fitted a consumer unit for us about 10 months ago.
You
Yes that's right, how can I help ?
Customer
Well the thing is I have just been browsing websites, and I have found the consumer unit you fitted is no longer compliant.
You
Yes there are new regulations concerning the materials used, but don't worry because it was compliant at the time of installation.
Customer
Well I am worried, because its not just a matter of a change in regulations is it !!
You
What do you mean ?
Customer
Well the regulations have been changed due to a potential fire hazard with the consumer unit you installed.
Apparently the materials used are not considered as non combustible.
I therefore feel I have been left with a consumer unit that is constructed of sub standard materials and from what I read a potential fire hazard in my home.
To be honest, I feel they should be re called and replaced with the new all metal units free of charge, by you.
And that it's up to you as the registered installer to seek compensation from the manufacturer or whoever you feel is responsible.
When can you come and replace the sub standard unit please, as I don't want a potential fire hazard left in my home.
You
And this is the bit for your thoughts and comments lads !!!!!!!!!!!!!!!!!!!!!!!!!!
Re: So with the all steel consumer units on the way your conversation goes something
just remember that the titanic was all metal and complied with appropriate current regs.
No lifeboats, just a flood system.
[ElectriciansForums.net] So with the all steel consumer units on the way your conversation goes something like
This is similar to the recall of Wylex breakers (well not as extream) but you get the picture. If exery customer expected there install to comply with the current edition of the regs then it would be a constant battle.
Reply to So with the all steel consumer units on the way your conversation goes something like in the UK Electrical Forum area at ElectriciansForums.net
2 3
