R
Robin Leitch
Wow thank you all for so much advice it is extremely appreciated!
It's probably shrouded in smoke.Sounds like an appliance fault.. out of interest was there an rcd protecting the socket outlet? Pic of the consumer unit would be good to see
Since when has that been a legal requirement in Northern Ireland?i don't know about in england but in northern ireland it is legal requirement to have an EICR carried out and a certificate produced before any property can be rented so whenever you moved in there should be a certificate from then. i only know the because i test rented homes a lot of the time
Did you report this to the landlord ?.Thank you, the socket has been cracked for a few years however it is a moulded plug also....
