3 or 5 rung ones?I hear that Screwfix are doing some good deals on skirting-board ladders at the moment.![]()
You need to speak to a wheelchair user.Given that the great majority of items requiring to be plugged into a socket are generally used higher up that the floor - computers, radios, TVs, stereo sets, Satellite, electric clock radios, etc. I think it would make more sense to set an "optimum" level for sockets, say 1000mm or thereabouts. Low sockets as someone has already pointed out are difficult for not only the elderly but also anyone with a mobility issue - I for example recently tore all the ligaments in one knee and you would not imagine what an impact that has for reaching down and bending over even now some three months afterwards.
Higher level sockets would also remove the problems with small children poking things in.
Assuming also that the cables are run in the ceiling void there would also financial savings to be gained as well as associated environmental benefits.
Just me or do others agree ?
I did actually consult a wheelchair-specific diagram showing the preferred height of electrical items.You need to speak to a wheelchair user.
I’m not saying that all wheelchair users are the same, but many of the ones I have dealt with, prefer low level (300mm) sockets.I did actually consult a wheelchair-specific diagram showing the preferred height of electrical items.
you might need "working at height" training for the 5 rung.3 or 5 rung ones?
Someone footing the base would do, wouldn't it, Dopy, grumpy or any of the 7 dwarfs may be up for some part time working, Hey Hoe its off to work we go.you might need "working at height" training for the 5 rung.![]()
You just had to bring smut into to it Tel, didn't you? funny thoughhey ho, hey ho, it's off to work we go'
with a shovel and a pick and a hairy dick, hey ho, hey ho, hey ho.
Surprised you got away with that, that's the textbook definition of "new dwelling" on a change of use for part m compliance. Did you have to get that approved by the building inspector specifically?I recently fitted some sockets in the actual skirting board with the backbox recessed in the wall behind, made good use of the multi tool, feeding cables down behind skirting board to cavity under floor. the skirting was 25cm high, was in a grade 1 listed property. deepest skirting board was just over a foot deep going up stairs and landings, that was on in a old private school building that was being converted to flats.
Thanks all! Common sense not applied in our basement (all socksts ridicously high ) and was told it was regulation. Wanted to be sure when passing on advise to clients as I am an.interior designer. Thanks again!
I think they do both Pete. Page 135 in the catalogue next to the heavy duty sky hooks.3 or 5 rung ones?
I have a 13 year old, he is bigger than me already! I said a few years back "The day you can beat me in an arm wrestle I'll give you £100" he was a skinny little thing at the time so I thought it will be a while before I have to shell out some cash. Hmmm... we had an arm wrestle on Friday and it took all my strength to beat him. Obviously I pretended it was easy, kids seem to be so big these days!
Oh, he will have, then enjoy enacting his revenge ...My 13 year old lad is nearly as tall as me.... I'm 5ft 11.5 inches.... (Yes the .5 inches is important, as I used to be 6 ft and lost .5 inch somewhere....)
Luckily he doesn't have the strength of me, or I would be in trouble, as I'm always winding him up...
silly bugger. you had your hair cut.
Reply to the thread, titled "Socket height regulation in old home" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
