Socket Heights in New Extensions | on ElectriciansForums
Discuss Socket Heights in New Extensions in the Australia area at ElectriciansForums.net
C
chloebear
Hi All,
Do the heights of Sockets & Light Switches in a New Extension to an older property (one room) have to abide by the new regs for heights or can they be at the same height as the existing sockets etc?
If this project is to be inspected by the local building inspector then I would suggest that it is worth asking him first before fitting the sockets & switches outside of the disabled zones.
use r wrong the regulations state that the sockets have to be 450mm from ground and light switches 120mm to top.If u certify this u could get into trouble because u arnt following regulations.If u rewire a house u have to abide by the regulations at the right heights.Keep yourself right.Approved contractor
Joe,
All the documents state that existing installations DO NOT have to have additions installed to the new heights.
Part M generally applies to substantially refurbished and new build properties only.
To this day, I have never been pulled up on it.
rubbish- who told you that, this only applies to new builds not extensions or rewires to old properties , if in doubt ring your part p sheme provider and ask them they will say same.
You are tending to take building regulations and interpret that advise as IEE regs
There seems to be quite a lot of confusion since domestic installations were included in the building regs,so you are not on your own with this confusion,but time will eventually assist the industry to have a clearer picture
Reply to Socket Heights in New Extensions in the Australia area at ElectriciansForums.net
Hi, We would like to have installed new single powerpoints which are on the skirting boards of our old house. However the existing ones we have...
J
Tiling over screed/plywood floor with height differences. Hi guys. Im a carpenter who has tiled a fair few floors over the years as i fit a lot...
Johnny
J
