socket in 1.5 | Page 4 | on ElectriciansForums
Discuss socket in 1.5 in the Australia area at ElectriciansForums.net
Such a simple question has turned into a 4 page debate
Im confused as to why people are asking what load is going to be on it and designating it by label etc....
Without doing the calcs the maximum load permissable through a 1.5mm is 19A, so wire it in 1.5mm, regardless of what you plug in to it, DVR or no DVR, kettle or toaster, by fitting a 16a mcb, overload protection will kick in after 16a to protect the cable, i dont see why people have "foggied" the question ?
But will it "kick in" after 16 A vernam? I thought MCBs to BS EN 60898 will take overcurrent to 1.45 times the rated for upto an hour before going.....
This is proving to be a good debate however the original question although very open
"can u use 1.5mm cable feeding a single socket from the DB on a 16a breaker?"
I would say has been answer by many - yes
That said we all, (I believe) would use 2.5 for the wiring of any sockets
Reply to socket in 1.5 in the Australia area at ElectriciansForums.net
I would chase the wall and fit 2 single sockets. A dual backbox can make fitting easier. Those click modules are soft plastic and feel a bit...
Yeh im unsure without a photo of external box.
