Discuss socket on lighting circuit? in the Australia area at ElectriciansForums.net
If it is to be used for a specific purposes, i.e TV equipment, I read on here few weeks ago that as long as it is labeled accordingly this is in-line with the regs?
Is this correct, would like to know myself.
NOT A GREY AREA. YOU CAN'T DO IT. Each circuit has to be separate for a start and another half dozen regs that it goes against.
That's going to be fun for the next guy who works on the lighting, can imagine spending hours trying to find a lamp in somewhere cocking up his test results when it's something connected up in the loft. Surely there's something else up there you can tap into? Or just run a spur up inside the airing cupboard?
Rather than fitting a double socket with square pins i would fit a single round pin and label like THIS stops somebody inadvertently sticking an electric fire into it.
Reply to socket on lighting circuit? in the Australia area at ElectriciansForums.net
