Socket ring circuit 6mm to 2.5mm - interesting! | Page 3 | on ElectriciansForums
Discuss Socket ring circuit 6mm to 2.5mm - interesting! in the UK Electrical Forum area at ElectriciansForums.net
kkkkk
Hi all
Working on a site with a general builder who planned on doing all the electrical work - total rewire - on the job, and is miffed because the home owner decided to call in a qualified electrician and get his certificates - builder has run some lighting cables, any old cable he had lying about (4 core/immersion heater cable/etc), which I'm replacing - and told us that he was going to run the ring circuit to start in 6mm T&E from the Consumer Unit, then (after an unspecified distance) to a junction box to split into 2 x 2.5mm T&E. Obviously he wasn't going to test, or notify, or certificate the work. Like to see the comments :)
I was not getting "personal", rather, I find it hard to understand why experienced sparks would ask the NIC (or anyone else for that matter) for guidance or comfort on such an issue. If it is not your opinion why are you trotting it out on here??
I know a lot of sparks on hear dis the nic and other reg bodies, but I personally have never had reason to complain about them.
Your comment on hard to understand why experienced sparks contact nic for advice is strange, as that is one of there functions. You could say it's hard to understand why experienced sparks ask this forum for advice.
I have contacted the nic in the past for a second opinion, but I know in the end it's my decision that matters.
I've also contacted this forum for advice.
Nothing wrong with that as far as I'm concerned.
I have spoken to NIC & a "lollipop" ring circuit is described as being unconventional, not incorrect, but not advisable - as said, it has been used when alterations were done in existing wiring where an old cooker circuit has been used. The main reason it is not a good idea is for the future, when testing is done and the joint where the 6mm joins the 2.5mm cannot be tested, as it would normally be hidden from sight and probably inaccessible, plus a future tester would not know the format of the circuit. Thanks everyone for your input, I had not heard of this before. :)
Run a 6mm to an isolator then a ring from there on, quite popular in schools, workshops, labs etc.
Reply to Socket ring circuit 6mm to 2.5mm - interesting! in the UK Electrical Forum area at ElectriciansForums.net
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
