Sockets tripping ...Help Please | Page 2 | on ElectriciansForums
Discuss Sockets tripping ...Help Please in the UK Electrical Forum area at ElectriciansForums.net
C
cassie08
Hi,
Yesterday while I was ironing my electric blow..just down stairs sockets had to reset..rccb load split yellow tab..thought thats it a new iron..so went out and brought a new one..plugged it back in to same doulbe switch but other side..after ironing with new iron for around 20 mins same again ..blow elec....thought must be double socket..will call someone out Monday..well this morning plugged iron in again..different room and after 20 mins again blow elec..any idea's Thanks..never had a problem before.
It may be a joke in this instance but joking aside I recently did a re-wire in a flood prone area and removed 2 or 3 sockets to find a netwok of shrews living behind them..............
If the waterways flood the vermin find dry places for refuge and gnaw everything in sight.
true..I can see your point there..little buggers can get everywhere..
- - - Updated - - -
So have you tried it upstairs to see if you have the same tripping problem? This will rule out the iron if the RCD stays on.
I have seen new appliances that have been faulty in the past although not very often.
Will go and try this..Thanks
Having done a bit of PAT testing in a hotel it seems LCD TV's are quite earth-leaky, so three of them on the same circuit may be enough cumulative leakage to make the RCD go? Anyone else an opinion on this?
Just plugged iron on upstairs..would it trip it straight away..
never had a problem with TV's..have two teenage lads ..so have tv's computers..xbox's..cooker..lights..fridge/frezzers etc all running at same time and never a problem.."scratching head"..Thanks for all replies
You could also try the iron with everything in the house unplugged to eliminate other electrical items from the scenario
- - - Updated - - -
So did it trip?
Reply to Sockets tripping ...Help Please in the UK Electrical Forum area at ElectriciansForums.net
Or just save all the agro and get a proper sparks round for 45 minutes to test the supply cable and re-fit the socket 'properly'
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
