Solar iBoost died | on ElectriciansForums
Discuss Solar iBoost died in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Ajax123
Lincolnshire
Hi all
I have a solar iboost unit on my hot water system. It's about 3 years old. It's been working fine up to now but appears to have died. The display is completely blank, no lights, no messages, nada... and we have no hot water. Must have happened today or maybe yesterday cos my boy was the last to use the shower yesterday morning and it was hot then....
The mains into the unit is fine running from a fused spur with power getting to the unit (well ... to the end if the feed cable anyway ). The immersion heater may have failed (yet to check) but I doubt this would cause the unit itself to fail would it.
Do these units have some sort of internal battery that might gave failed or is it deceased? Have looked at various troubleshooters and found no help at all...
No idea, you asked if it had an internal battery and one of the units does, I would be tempted to switch off the supply, not forgetting you can't switch off solar panels and take the control unit cover off to see if there is an internal fuse.
Looks like i might have to. I know there's no fuse but maybe an internal keep je alive type battery...
I tried new batteries in the sender... no joy
Seems pretty stupid having a replaceable part permanently soldered in place, obviously built in obsolescence. ?. If you can determine the value, can you replace it, but obviously see if you can find out why it blew in the first place.
Its a 16A ceramic fuse. I'm guessing as its 16A means it cant be classed as replaceable.
I have a plan...
I think it blew because the immersion heater blew up... the neutral cable had come loose I think and arced. It was probably quite pretty... What I'm more annoyed with is the 13A replaceable fuse in the spur still works fine... I'll be speaking with Marlec next week. As you say need to double check reason it blew before recommissioning it. Maybe it looks like it says 16A but isn't really.... maybe 1.6A??
It could be that Marlec designed in a 16A fast-blow fuse to protect their solid-state device (thyristor?) that controls the power into the immersion heater. That would account for why your 13A fuse didn't blow.
It's also possible that, despite the 16A fuse going, the fault took out other things!
Indeed. I shall see soon I guess...
Reply to Solar iBoost died in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Whatever... I awoke this morning ready for an intersting and relaxed day at work at my local branch of the Men's Shed charity. " jobs pending...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
