jason121
3 x 2kw star at neutral
Discuss Solar immersion device capable of running 6kW immersion in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Since Posting I have come across a 3 phase Diversion Device .
No knowledge about it apart from what I have read .
http://www.mk2pvrouter.co.uk/61101.html
But @ Solar City as your requirement is for powering a single phase immersion element I am sure it is not going to help at all.
But it may be the answer for someone else .
However I am certain that any of the proportional devices will not mind a 6 Kw load .
As they are limiting the output to match power available .
A lot of the time they putting 2 or 300 watts into a 3 kw load . they are virtually never supplying the 3kw into the 3Kw load except on "over ride " mode and you should be able to disable that feature without to much trouble .
IMO getting optimal self use out of a 3 phase installation in a domestic situation is not easy at all .
Reply to Solar immersion device capable of running 6kW immersion in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
