solar metering faults | on ElectriciansForums
Discuss solar metering faults in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
justoldmikey
Hi I have long retired as an electrician,so all this solar is over my head.I had some 20 panels fitted to my roof in January this year,so a 3.8 KWT system.I was told that in daylight hours me and my old dutch would be able to use the electricity generated by the panels,that is using one bit of electrical equipment at a time i/e best practice.what is not used goes out to the Nat Grid and we are payed FIT.Is that OK so far?
Now here is the problem,in 9 months The generated electricity is good and FIT is high,but the utility company tell me solar has made no difference to my bill or usage.I done a small test myself.( With nothing switched on in the house accept the fridge and freezer,and under their thermostat were not running.on a clear sunny day,I plug in the hoover, current/electricity flows and is being supplied from the Nat Grid I also tried the same to boil a kettle of water the same happens.Iv had the utility meter tested and the electricity company has said there is no fault with their meter.The installation company recognize there is problem.The meter for the solar is an Elster and what I can gather is recording OK.The MCS is looking at the problem as well.
For me it looks like all that is generated from the solar is going straight out to the Nat Grid,and not supplying the house its self
If there is any one out there who would kindly point me to the likely cause of the problem/fault(so i don't look a complete idiot) when I have to talk to the installation company or when I get a electrician to repair the fault.Any help or advice will be appreciated
Are you sure the PV system is connected correctly? It sounds like it may be connected to the 'supply' side of the incoming supply meter. Therefore all generated power is still registering on that meter.
I doubt it would be this simple though as your installation company or the DNO/supplier would have picked up on this by now.
The meter might not have reverse energy detection built in which could mean the incoming supply meter is not stopping when there is enough energy from your pv to run your house. I may have got the wrong end of the stick here though?
3 options
1 - the installer wrongly cut the tails between cut out and suppliers meter and installed to a henley block at that point, so the solar generation is on the wrong side of the suppliers meter to impact on consumption
2 - Your suppliers meter has an antitamper setting so it clocks up in both directions - if you actually do use 50% of generation then this wouldn't show up over the year, but should do in summer when. The most common meter for having this problem is a Siemens meter, blue and grey, I forget the model, but others can do this. Test it out by turning the main switch off at the CU in bright sunlight and seeing if the suppliers meter is still clocking up when it's dyefinitely exporting.
3 - You've left your immersion heater switched on or something similar that accounts for an actual increase in electricity consumption.
Thanks the problem is the installation company blame the utility company who in tern say their meter is working OK.Me Im just piggy in the middle.But thank you for your help, the connection is something I think is wrong
1 very interesting but I cannot get installer to come back to check,and haveing to get MCS to chase them,but for me I think that could be the problem.
2 The suppler says that is the standard meter they use (Actarist)
3 I wish it was just that, would save me a lot of time.But thank you for your help
Have the installer actually been back to site to check?
You really need to post a picture of how the meters are connected. We could then rule out the most likely problem; that the PV system has been connected incorrectly.
[ElectriciansForums.net] solar metering faults[ElectriciansForums.net] solar metering faults[ElectriciansForums.net] solar metering faults
Thank you I don't know if these ar OK the connection is on thr far right
Hi thanks for that, M C S is currently chasing the installer company.Sorry the photos are the best I can do as I find it difficult to get down to the floor level to do anything,But thank you for the reply I now know that with the wonderful respounce I have had the fault in this system is not my imagination and now I wont be fobed off by the installation company
Hard to tell from the pictures. Is the PV system connected directly to the consumer unit? It isn't that cable connected to the main switch is it?
View attachment 21128View attachment 21129View attachment 21130
Am I interpreting that right, that the solar is sharing with the main incoming tails on the supply side of the main breaker?
I suppose that's one way to avoid the issue of RCD trips on a split RCD board, but it looks to mean that there's no overload protection... probably not actually an issue in reality as it's a current limited device, but overload protection is specified in G83 regs if I remember right.
So anyway, back to your problem... I'm not aware of issues with that meter, and the solar is connected to the correct side of the meters, so I'd think the most likely cause is either a fault somewhere in your house / appliances that's resulted in an increase in consumption, or you or someone in the house has been doing something like turning the immersion heater on during the day to try to make use of the solar, or the immersion has just been left switched on or something like that resulting in an actual increase in consumption levels.
To try to work it out, I'd probably put a henlye block in to split the tails to bring the solar in at that point, then install a standard clip on monitoring device such as a current cost unit to monitor your actual consumption - maybe even use the optical reader to monitor both meters at the same time, then work out what's actually going on.
Reply to solar metering faults in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I have a recurring DC Interference fault on my solar system. I have gone through all the scenarios recommended by Solis, but still no solution...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
