Well thanks for the advice Geordie, I managed a couple of hours to play around this afternoon so I bought some fittings, a small nozzle for my oxy-acetylene kit and a couple of different blowtorches and these were the results;
Definitely an improvement, I might make the grade as a plumber yet
Thanks again.
"Hello Marvo",
Excellent Soldering ! You really have made a VERY Good job of it !
However I must respond to the comment from shanky887614- I assume that You were Joking [?]
If not: Plumbers are NOT trying to Solder to that standard even at College - they are making Water Tight Joints.
Can You imagine a Plumber trying to Solder to the standard that Marvo carried out / has shown in His Photo`s - throughout a House / Flat - how long would that add to the Installation / and Cost ?
That is apart from the fact that it would be Impossible to achieve !
There is also the fact that unless Solder Ring Fittings are used - when Pipes are horizontal in notches across Joists there will always be a small `run` / `blob` of Solder under the Joint - at the lowest point - this should obviously be wiped off on Surface mounted Pipework.
Regards,
Chris
P.S: Marvo - Regarding your question about Prices for Plumbing Fittings including 54mm End Caps - these range in price here in the U.K. ridiculously from about ÂŁ20.00 inc. Vat to up to ÂŁ70.00 inc. ! - the ÂŁ70.00 one that I noticed was a Delcop End Feed [Solderless] 54mm End Cap !
HERE IS WHERE I WAS LOOKING:
54mm Soldered End Caps/Plumbing Supplies - Google Search
P.P.S: I found a Supplier `Plumblink` in South Africa on that webpage - they are showing 54mm End Caps in Stock - IF I am correct that there are about 15 Rand to the Pound regarding their Price of R76.55 - this looks to be just over ÂŁ5.00 UK - Plus VAT - ?
They apparently `Deliver anywhere in South Africa for R200.00`
Here is a Link: 54mm Copcal Tube End Cap 617M
I hope that this might be helpful.
Chris
