My view is you're probably bored and trying to create conversation where there is none to be had. You're going on about containment but why would this enclosure not meet the relevant IP ratings?? It looks pretty good to me. If you first fix a property and come back to find the plasterer has added an extra 10mm depth of plaster, I presume you remove all your KO boxes and pack them out by 10mm?
I was genuinely curious because I have been asked this in the past and thought it was an opportunity to get other views. If a plasterer has added to the depth of plaster then you should fit back box spacers.
How is a light switch different? The back box is often behind the plasterboard so the switch and backbox aren't together the plasterboard is sandwiched between.
You can get them but Ive only seen them in 16,25,35mm deep.
UK Elecrical Supplies - https://www.ukelectricalsupplies.com/norslo-extension-steel-boxes-2-gang-16mm.htm?utm_source=google&utm_medium=shop&utm_campaign=feed&gclid=CKr3mYbkpdACFQ8TGwodZVYMsQ
You'd have to be a complete fruitcake to go round a whole house fitting them though, just because a plasterer has added a bit more depth to the plaster.
Actually we used to fit loads of these when needed. More when you have 50-100mm gap between back box and finished wall. Weather that is because of plaster or over enthusiastic laborers doing mad chases or even the odd occasion where you get industrial type partition walls which can be well in excess of 100mm thick ect....plenty of uses - bloody things used to give me nightmares as an apprentice due to it being "My job" lol.
But as for the "containment issue" mentioned above - I think surface mounted onto wall on top of flush box is absolutely fine - fabricated containment using building fabric meets all ip requirements ect.....If we were talking about inside an explosive environment then we may have a shout for a "better" solution...but that really is being pedantic lol.
Well this is an exciting thread isn't it, filled with interesting technical discussion and a chance for us all to learn something!
I think the OP and I are going to get on like a house on fire :)
Any other neat solutions to get from below surface to over surface conduit?
Assuming you are talking about t&e or other sheathed cable then its often easier to use mini trunking in such a situation, just butt it up to the existing socket and drill through into the flush box.
For a proper conduit job then chop the wall out a bit and use a double set to get the conduit below the surface of the wall, then just coupler and bush or two lockrings and bush into the flush box
Ware Herts
Website
http://www.sparksofintelligence.co.uk
Business Name
Sparks of Intelligence
Solutions for Surface mount to conduit.
Pat H,
davesparks,
