Solutions for Surface mount to conduit. | Page 5 | on ElectriciansForums
Discuss Solutions for Surface mount to conduit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Assuming you are talking about t&e or other sheathed cable then its often easier to use mini trunking in such a situation, just butt it up to the existing socket and drill through into the flush box.
For a proper conduit job then chop the wall out a bit and use a double set to get the conduit below the surface of the wall, then just coupler and bush or two lockrings and bush into the flush box
Butt the trunking up to the socket and drill through through the back box, never had you down as a housebasher Dave:)
Reply to Solutions for Surface mount to conduit. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
And if it's a garage then use metal clad accessories.
