Hi guys,
I've got alot of questions that i'd like to be answered.
1) Is a double socket counted as 1 point served or 2?
I count it as one, and have read somewhere on here that its one, but a few people in work are adamant that its classed as 2. Is there any hard evidence that its classed as one that i can show them? What is the reason for number of points served?
Light switches? Are they counted?
PIR's? are they counted?
Spurs - do you count them or what they are feeding? or both?
Isolator - do you count them or what they are isolating? or both?
Is there any documentation on number of points served? as it seems to be quite a few people including myself are unsure about it.
2) PFC
Scenario: Lets say there is a pfc of 25KA at the mains which is protected by bs-88's, thats fine right. But then I have a pfc at a DB in that installation of 19ka, it is covered by 60898 breakers (10ka rating) I know these breakers would not be sufficient for the KA, but if that kind of fault current was flowing that the 60898 breakers could not operate the bs-88's at the mains would operate and cover the DB, so would that be a valid arguement that the board is covered?
Am I making any sense?
Outside Lights - they dont have to be covered by an rcd right? if they are out of reach fair enough, but what if it is low level surely it should be covered? it says in the regs that all mobile equipment for use outdoors is to be covered by an rcd, so spurs do not have to?
Periodic inspection:
Lets say the installation your testing does not conform to the 17th edition,
For instance if you have sockets that are not covered by an rcd, what do you do? does this mean it fails? Do you right it down as a recommendation? Or is it acceptable, because im guessing it conformed to the regs at one point...
No cpc on circuits, just trunking and conduit as an earth, is this ok? does it fail? do you right it down as a recommendation, because again at one point this conformed with the regs.
No rcd on circuits in bathrooms/swimming pools etc, is this ok? does it fail? do you right it down as a recommendation.
This guy in work said that having live parts showing in the board (old c50 type) was a fault and he gave it a code 2? I said to him, its a board, it's meant to? Is he right? Surely not?
Do sockets have to have a flying earth lead to the back box? I always do it, would you right it down as a fault on a new installation?
Ceiling grid, does it have to be bonded? the lights that sit in it are earthed, would this be sufficient?
******EDIT**********
Another question i forgot to post
Water and gas bonding, how do you calculate the size of the cable used? does the size matter as long as its under 0.05 ohms? or am i getting mixed up?
Another scenario, 300mm2 singles feeding a 3 phase main DB, neutral is 150mm2, the MET is not in the board but on the wall at the side of board. a 75mm2 earthing conductor is coming from the cut out, which is ok yeah? half the size of neutral, but then it only had a 35mm2 coming from MET to board? is that ok? as the regs only says about the earthing conductor from cut out to MET, not from MET to board.
*****edit****
I know its a lot of questions, but i would be grateful if anyone can answer them.
Cheers,
Aaron
2) PFC
*****edit****
Cheers,
Aaron
