Guest viewing is limited
Because you shouldn't mod any ex equipment whatsoever. It all has to be as it came.
That's what I was taught on the COMPEX.
I know that makes no sense RE the heat shrink but it was presented as black and white as that.
I also don't understand Adam regarding the no shrouds thing, they come with the glands so should be on shouldn't they?
Manufactures spec trumps all doesn't it?
Never heard of that one before, so what's the reasoning behind that little gem then?? Shrouds can be slipped down for gland inspection and any glands used, will be of the suitable EX'd type!! So i'm at a complete loss, considering the shrouds protect the SWA against the elements etc????? lol!!
We use adhesive lined heatshrink on all our external SWA glands, and personally i'd be using the same on hazardous area installations as well, unless anyone can give me a good reason not too?? ...lol!!
I haven't a clue pal it's what has been specified by the client the glands are by a company called cmp I think not to sure though. We got told that if a shroud is on it collects water. It's all to do with compex they have someone inspecting the glands for marks and that they have made off propally
Some EX equipment is designed with flame paths to allow the flame/explosion to escape in such way as to dissipate the energy to safe levels ,you should never over tighten the glands for this reason or modify EX glands,The flame paths can be the threads on the gland if they're sealed up they cant function as designed.
On some sites i was on that didn't allow shrouds it was to make sure corrosion was spotted ,the shrouds protect against the elements but can hide damage and trap water. Also on one site we came across some vendor glands that weren't LSF/LS0H and had no markings as to differentiate from similar LSF/LS0H shrouds so the engineer said they all had to go
Well you can't go far wrong with CMP glands, they are one of the best manufacturers.
I have a set of these for making off glands but in 250mm size, by far the best imo. Like pump pliers but smooth so no issues if you slip you won't gnarl up the gland.
Knipex plier wrench
These are great,At this stage i wouldn't go near a gland with any other type of pliers (that is type not brand ),i also use an adjustable/spanner but nothing with teeth,with more and more being inspected ( a lot of Atex sites) its just not a good start for the first thing an inspector to see is a battered gland. I'll be honest and say its forces better habits on you, starting with the right tool for the job
The Hawke branded glands are IP66 rated without the need for a shroud. Certification for the gland needs to be visible for visual inspections. Also the salty air hardens the shroud over time making it near impossible to remove without damage. If I come across a shrouded gland on a relatively new installation offshore then it is usually trying to hide something lol.
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Shrouds or any covering on a gland for that matter allow a build up of moisture and quite possibly the gas or whatever is in that hazardous area, that’s why we’re not supposed to use them in hazardous installations
I can understand if you’ve never heard of this if you’re not in the hazardous area field. I first heard of it about 7 years ago, an engineer from Hawke (the gland company) visited our site and said they were starting to advise against the use of shrouds in hazardous areas.
Well that's put that 8 year old thread to rest then 😀
Northwest
Spanners for swa glands
Electrical Tools and Products
Adam_glover18,
Thedeep,
