Priced a job to change old 3ph board from pictures alone. No the firm so jobs good.
Get there and situation is no spd fitted on existing. So I was going to fit one to my new db in trunking at side of board fed of 32a breaker.
Will this act / cover / work for the whole site.
Layout is main switch with 2 outgoing sets of 3ph /n tails to 2 dbs next to each other.
Both boards will be on at all times, as only problem I can see is if db was turned off.
Or am I looking into it too much. Customer wants it right and understands if there is a better way.
