speaker wiring | Page 2 | on ElectriciansForums
Discuss speaker wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
We use BS7671 not NFPA NEC over here.
Just to add. For my home I used 6mm tri-rated singles as they were free from where I worked.
Free, or f-r-e-e - As in they just followed you home?!
I'll let you all in to a little trade secret from the entertainment industry, but promise you don't tell anyone!
In nearly all theatres, cinemas, studios etc the super special speaker cable is either singles in trunking or T&E
And it sounds just as good as any of those class 5000 oxygen free cables!
And what's more, from around 25 years old, hearing starts dropping off at both the high and low ends of the spectrom. So from around 30 or a little later, the human ear can't hear any miniscule improvements that high end oxygen free speaker cables may or may not provide. Most of the improvements these high end cable give, are for the most part only seen on sensitive measuring equipment....
Always used to make me chuckle reading HiFi magazines where the authors of articles sending up the praises of certain speaker cables and the like were in there 50's!! By that age their 20Hz to 20KHz hearing is just a distant memory!! lol!!
If your really worried about it, use two core flex. It really is as good (probably better!) than any speaker cable with bells on. And it will have met all the relevant standards for your country
Were talking about speaker cable here, not 11000 volt cabling lol, whack some speaker cable in and forget all about it, it is for some speakers in someones house not the Royal Albert hall.
PARDON??!! :wheelchair:
6mm single / tri-rate is all I use in an install situation. Just remember that it's two cables to each location!
Reply to speaker wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So much for trying to steer this back on track.
2 3
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
