How much do you pay him?
I've known 40p per item, but 16000 items would take me considerably less than a year!
Haha... It is not his only job. He is PAYE. We try not to do subbies. He also does the visual inspections, emergency lighting tests and re-lamping jobs.
Sub it out 50p an item if you have more than 1000 items,and no liability and you can make it look good on a risk assessment that your using specialist contractor.Who will use muppets but the HSE love paper work.
Blimey lots to reply to now so bare with me :p
Sorry just got home from a afternoon of PAT'in LOL
Well firstly....
The hospital job well that was a kind of blessing in disguise as it turned out it would of been a bad call!
In a nut shell though I was offered the job and waiting for the written confirmation before handing in my notice. Anyways after a few days I had not heard anything so rang the manager that I had met who who then informed me that accounts had put the brakes on my employment and decided they didnt need anyone to replace whoever left.
But then because I had not been taken on apparently they lost staff hand over fist due to excesive work load so god knows what happened there in the end!
Back to topic....
So I will explain the circumstances a little better, The team I work in is small and our main job is to tend to the facilities (Electric, Water, Gas, AC etc) We also have to attend breakdowns and carry out various maintenance etc etc.
And then we have the PAT testing which is spread over the course of the year, But due to the equipment being in use, access etc we only really get the chance to do it on lates and the weekends (providing we have nout else that commands our attention!) But we are talking 10k+ items!
Just to add a additional fish slap accross the face most of the stuff is not easy access, We are not talking getting stuff off desks here.
Alot of stuff is mounted to frameworks above conveyor belts, Long extension leads tied to unistrut frames (dont get me started on that), Cables tied to everything and anything to keep them "neat" you get the idea.....
So as ime sure you can imagine its a really time consuming task, If I can do 60 items in a shift ime doing bloody well!
So currently all known and previously tested items have a barcode sticker with a unique number, a asset number and of course a pass label.
All of that info is kept on a central database (PAT guard) and thats what we work from as best as we can.
God knows we wish we could contract it out but due to the awkwardness of the job I dont think any companies want it, except for ones who wont do it properly (we trialed a few).
So yeah I was thinking the barcode system would be the way to go, Am I right in thinking the barcode labels we use allready would be compatible with the barcode scanned for the seawoods? I assume they are all the same?
And to the guys who have used these systems before, How does the process work exactly?
Ive always done it olde school with pen, paper and stickers but I must admit trying to write out a label when doing the splits accross a conveyor is not easy!!
If you sub it out you are still responsible for the job.
Blimey lots to reply t0
You won't need the pen and paper lol.
As the assets are already stored in your pat tester it should just be a case of plug and play. When you scan an asset the details will appear on your machine with the options for your test. If your test is a pass just print the label off there and then; you won't want failed items labeled I assume, so fix and print.
When you add a new asset scan it and add the details to your tester, they will be there till you delete them, you can bring stored asset details up at any time by just scanning the item.
The printers can be clipped to your belt for those awkward places too.
As you already have Patguard I assume you are familiar with the record keeping facilities, but incase you don't know it has a test due warning facility that can be emailed to yourself or your customer. It can also print out all the asset records and test results that may be required.
You can download all the instruction manuals and loads of other information from Seaward, or phone them , they are very helpful.
It will read it and let you assign it to a new asset. It will not have the previous details unless they are stored in your tester. if you have the previous details you can enter them into your tester but I am not sure if they will auto load to Patguard, you may be able to store them as a new client.
It will read all the barcodes and results if they are in your tester.
If I can find the disc I will have a read up tonight. I am a bit rusty as I have not used it for awhile.
Telford
Speeding up testing of a large site....
Electrical Testing & PAT Testing Forum
Tiny Spark,
ruston,
TrueNAS JBOD Storage Server
