Split Concentric Termination | Page 2 | on ElectriciansForums
Discuss Split Concentric Termination in the UK Electrical Forum area at ElectriciansForums.net
catdog
I'm no expert on split concentric (assuming that's what this is)......But an earth clamp doesn't seem the best solution to this (also as the earth cores appear to be insulated!
This is for an eicr on a sub main but I'll have to do the remedial work at some stage.
Any advice on how to terminate this correctly?
Thanks!
[ElectriciansForums.net] Split Concentric Termination
Reply to Split Concentric Termination in the UK Electrical Forum area at ElectriciansForums.net
Not the centre core connected to L as exposed here. When used by the DNO it all is enclosed in the cut-out. It is in my mind fairly safe in the...
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
