N
newtothis
I think I count 4; possibly 5 issues of concern. What do you see LOL
![IMG_3713_zps6d2fadc0.jpg](/proxy.php?image=http%3A%2F%2Fi1117.photobucket.com%2Falbums%2Fk593%2Ftrevspics%2FIMG_3713_zps6d2fadc0.jpg&hash=3139ad0a5582366e963076943c2cdc40)
If that is supply for the boiler it shouldn't be on a plug top in an unswitched socket though
**Edit**
Unless that unswitched socket is fed from its own isolator somewhere (unlikely!)
Are you thinking along the lines of 554.3 BGB?
Do I get any points for 528.3.1 ? :ears:that reg. is not applicable to gas boilers. could be the source of his confusion.
only for the flex being tight up agin hot pipes.Do I get any points for 528.3.1 ? :ears:
Ive been told by two heating engineers in the past that they had to be on an FCU, one guy wouldn't sign off a landlords ticket for the gas as the combi was on a plug top. No idea who's rules/regs but that's what I was told
There is an important lesson for any trainee to learn here, don't ever trust anything the plumbers tell you!
Next time you encounter this politely ask the plumber to specify exactly which regulation refers to this, they won't be able to.
i prefer them on a FCU, if only for the fact that some dumb mrs mop might unplug boiler to use a vac.
Read an interesting point earlier when I googled this situation... 'A socket and unswitched plug would be compliant as you have to remove the plug to isolate but a switched socket could only be single pole so not providing complete isolation' it was on the iet forum and makes an interesting point.i prefer them on a FCU, if only for the fact that some dumb mrs mop might unplug boiler to use a vac. a socket outlet provides a compliant means of isolation, so would comply with regs. tin hat ready.
