Spot The Mistake | Page 3 | on ElectriciansForums
Discuss Spot The Mistake in the Australia area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
yep, similar but not as ancient. i think that around the early 70's heads were supplied with the block attached in readiness for PME, but no link across to the neutral in the head. the way to be certain is to measure the pssc and pefc. if the readings are identical, then its TNC-S. if the pefc is lower than the pssc, then it's TN-S.
I don't like the tone of your inference there young man
LOL. as i,m older than you malcolm, it's obvious that i was referring to the service head. a pot never calls the kettle black. one thing was a bit of a head scratch was the main bonding. gas meter was below the CU board and done in 6mm green, but then there are 2 imperial equiv' of 10mm going up and over. 1 is to water, but couldn't find the end of the other 1. using wander lead, the water main bond read 0.03ohms, so well in.
managed to finish around 6.30pm. not 100% happy with a couple of the cables in the CU. going to re-dress monday, but had to extend some and couldn't leave without power for obvious reasons. also lost an hour going out for an RCBO and fixing a couple of faults, so was a bit pushed for time. guy wants me to do a bit of outside lighting for him, so will do at same time.
Reply to Spot The Mistake in the Australia area at ElectriciansForums.net
Your biggest mistake is admitting to a mistake.... If theres no witnesses, it didn't happen. However.... A few golden rules.... Never trust...
That'd be a great help mate. You could attempt to use chat gpt. Instruct it to rewrite the following and paste the lot in and 50% of the time it's...
