Spotlights Measurements | Page 2 | on ElectriciansForums
  • Thread starter NathanMorgan
  • Start date
  • Replies 21
  • Views 6K
Discuss Spotlights Measurements in the Lighting Forum area at ElectriciansForums.net
when measuring out spotlights in a kitchen what is your initial measurement from the wall to avoid shadows reflecting beneath cupboard units etc.
would you go 600mm/700mm from the wall to avoid this issue and then begin your spacing calculations?
Thanks.
Recessed Downlights - Top Tips For The Perfect Layout / Lighting Ideas - Lighting Direct - http://www.lighting-direct.co.uk/ideas/recessed-downlights-top-tips-for-the-perfect-layout/
thanks for all of your replies.
Another quick question, say im installing 10 spotlights and the length of the room is 3.5m and width is 2.5m.
I would divide 3.5m by 6 to give equal distances from each spot and divide 2.5m by 3 etc.
so 3.5m divided by 6 = 580mm.
say I need to bring this first spot out to 700mm due to kitchen units/worktops etc, how do I then modify my calculations for the other spots to be equal distances apart and the distances from walls?
Thanks.
Why divide by 6 when you have 10 lights,am I being a bit thick here.
Maybe two rows of 5?
5 lights = 6 spaces between them!
Hum... Think fence panels and fence posts ..... The posts are the lights , and the panels are the spaces between them
So 5 lights would have 4 spaces,
Thus 3.5 minus 0.7 x 2 = 2.1 divided by 4 = 525 mm , which IMHO is far too close together unless you are lighting an operating theatre!
Your fence doesn't have any walls!
I was starting and finishing at the walls.
Wall * * * * * Wall
That's 5 lights and 6 spaces
You may want a different dimension between the walls and the first fittings, but that's just simple arithmetic to work out the spacing.
Reply to Spotlights Measurements in the Lighting Forum area at ElectriciansForums.net
Thanks FG. I am thinking of using Octopus Energy for the work now I know there is at least one feasible solution. Any views anyone?
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
