spotlights | on ElectriciansForums
Discuss spotlights in the UK Electrical Forum area at ElectriciansForums.net
L
lofty84
Do you guys have a prefered spotlight. I need to put some spolights in a bedroom and I wondered if there was a make which is good value and god quality. the room size is 8ft x 9ft and I was going to 9 spotlights in it but dont know if 6 would be better.
not sure is there a rule of foot when it comes tot hese things
your pm box is full M8
I have fitted plenty of Robus GU10 fire rated in the past, so feel qualified to say that they are absolute garbage. Thin flimsy guards over the connections snap off half the time leaving you with an unusable fitting. The connection box is tiny, as are the connections themselves, don't even think about using 1.5mm cable.
Go for JCC GU10. Good quality but also cheap. I get them for £5.50.
Ansell iCage are also a good fitting.
Reply to spotlights in the UK Electrical Forum area at ElectriciansForums.net
EMailed to the forum for you @PCBWay
    • Winner
