Spur blowing RCD | Page 2 | on ElectriciansForums
Discuss Spur blowing RCD in the UK Electrical Forum area at ElectriciansForums.net
Glasgow, Scotland, United Kingdom
I'm trying to connect a spur to an existing outlet but when I use an appliance on the spur socket the rcd trips.
I've tested the rcd and it has 19 amps capacity which is as expected.
I've also tried connecting to a different socket on the same rcd and it also trips.
What I don't understand is if I use the exact same appliance on the internal socket it doesn't blow.
I've also tried using a different external socket but the same result.
I've connected the socket with a heavy duty cable and so that the original socket has three wires in each of live, neutral and earth.
Any ideas?
Cheers
Nope. Otherwise I wouldn't be asking the question
Just wandered why an electrician (someone with the specialist knowledge and test equipment) wouldn't test the cable/socket to at least identify if not rectify the issue.
Insulation resistance testing requires either an Insulation Resistance tester or a Multi-Function Tester with this function, something an electrician should have at their disposal.
Get back on to the electrician. He'll know a lot more than anyone on the internet having an educated guess.
What's he checked?
I'm doubting his existence to tell the truth.
Oooh you sceptic!
These are the connections in external socket
[ElectriciansForums.net] Spur blowing RCD
I'm just thinking if I hook up the external socket to a plug and then test with an extension lead that would eliminate the external socket and the wire being the issue.
The last useful thing you can do is try the kettle plugged in inside, and the drill in an additional inside socket. If that trips, then nothing to do with the wiring.
If not then you have done all you can do without getting in a good electrician who has and knows how to use a multi-function tester (these costs hundreds of pounds)
Any tripping if you plug in the drill indoors and switch on?.
Are you getting 230V L to E and (practically) 0V N to E on the outdoor socket
Doesn't trip when both inside. I will test L an e outside
While I agree conceptually with the tests, I'd have to advise that the outside socket is not reconnected until earth sleeving is added both ends.
I'd also have to advise that using a multimeter to do this test is rather dangerous with no earth sleeving in situ (unless it has GS38 compliant test leads).
Reply to Spur blowing RCD in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
2 3
