Spur direct from CU with another circuit | Page 2 | on ElectriciansForums
Discuss Spur direct from CU with another circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As ses knows, it would be fine as he suggests.
(subject to fault conditions being met which they will be for such a short run).
Max. load 13A.
Reply to Spur direct from CU with another circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
Many thanks. Very clear!
