OP
yarcyk
Washing machine and dishwasher if on at the same time and heating water can be around 4-5kW as both have similar heating elements.
Discuss Spur for diswasher and washing machine in radial circuit in the Electrical Appliances Forum area at ElectriciansForums.net
Nothing at all wrong with a radial. aslong as you install 4mm2 cable protected by a 32amp in the kitchen. 20amp with 2.5mm2 cable serving the bedrooms and another 20amp radial for downstairs.
Easier to 1st fix(no return to c-unit).Easier and quicker to test.Easier to fault find.Less cables in fuse box to 2nd fix. I think its the way forward. Some sparks cant see past the "ring final circuit".
Obviously i do still install rings but im leaning loads more to a radial circuit. My NAPIT assesor put me on to the idea "why u still messing around with rings" i quote.
The only thing on for any length of time is the washing machine, and that's only using 2kw when its heating.
i agree england is the only country to use a ring circuit invented because of the war. there is already talk of doing away with the ring curcuit so that once again we can fall in line with our european bretherin
Reply to Spur for diswasher and washing machine in radial circuit in the Electrical Appliances Forum area at ElectriciansForums.net
