spur off spur..? | Page 2 | on ElectriciansForums
Discuss spur off spur..? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Why don't you spur off to the first FCU with 4mm and then if the two fuses are changed to 13A its capable.
Although 2.5 is capable upto 27A clipped direct I have thought it safer to use 4mm as appendix 15 radial is 4mm for a 32A protective device.
Reply to spur off spur..? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
Yeh fuseboxshop.delivery up here only takes 3 days
