Square metres | on ElectriciansForums
Discuss Square metres in the UK Electrical Forum area at ElectriciansForums.net
Farmelectrics
Wirral
Having brain freeze at mo after few beers so just a quick one a 20a radial your allowed no more than 50 square metres how do I calculate this to metres if it was a straight run for my radial
So taking into account volt drop I would have to use 20a device Ie volt drop = 11x 20x43divided by 1000 = 9.46volts which is under the 5% allowed would you agree lads and that's me last post tonight going to watch the boxing thanks for your help
Reply to Square metres in the UK Electrical Forum area at ElectriciansForums.net
Tiling Rates Per Square Meter - How much does tiling cost? Tiling Rates Per Square Meter / Per Day – How much do tilers charge? I know this...
That is most interesting. I've sat transfixed and watched the same (scaled-up!) process being used to join two sections of rail-head together...
