Square metres | Page 2 | on ElectriciansForums
Discuss Square metres in the UK Electrical Forum area at ElectriciansForums.net
Farmelectrics
Wirral
Having brain freeze at mo after few beers so just a quick one a 20a radial your allowed no more than 50 square metres how do I calculate this to metres if it was a straight run for my radial
So taking into account volt drop I would have to use 20a device Ie volt drop = 11x 20x43divided by 1000 = 9.46volts which is under the 5% allowed would you agree lads and that's me last post tonight going to watch the boxing thanks for your help
well if your calcs are borderline and high loads may be expected from the sockets theres nothing actually stopping you from using 6mm other than an extra ÂŁ20 in cable.
......... aye ... and how the Hell is he supposed to get two lumps o' that inter his terminals on the back o' his sockets ..... withoot giving them a haircut? :yes:
(6mm sq. cables in Geordieland are like me ... quite thick)
well you can run 6mm from the the cu to the first socket which is 28mtrs itself - having a 2.5 cpc for the longest section will bring your Zs right down ;-)
wimps , everyone of ya , i should have suggested 95mm swa lol.
I wouldn't worry too much about the 50mm2/75mm2 floor area rule too much......getting the circuit calcs right is the main thing. The floor area limits are guidelines, actually I understand them to be historical guidelines........
Reply to Square metres in the UK Electrical Forum area at ElectriciansForums.net
Tiling Rates Per Square Meter - How much does tiling cost? Tiling Rates Per Square Meter / Per Day – How much do tilers charge? I know this...
That is most interesting. I've sat transfixed and watched the same (scaled-up!) process being used to join two sections of rail-head together...
