username_given
I'll start by saying - I have absolutely no intention of doing any wiring or anything electrical myself. You get someone professional to do a professional job - I know that. I just want to understand what I should consider so that I don't end up having to rip out or rework stuff afterwards.
The house in question is empty from 1930's and requires everything being done to it. Consequently everything is being ripped out. The kitchen was done in 1992 (from the wonderful newspapers under the lino) and at the time had a normal setup of a new kitchen ring put in - except the electrician couldn't get the return through the wall from the bathroom so it's a sort of radial with a load of spurs with the deserted unused return left in place. The majority of wiring in the kitchen was clipped visibly on the wall behind the units. It's all going - well gone. The whole house is going to have a full rewire - but we will get the whole house done once all the work is done.
I am currently chasing out the new runs for the cabling in the kitchen and as a bit of overkill am using FSU flexicon in the chases to the boxes so I can put everything in place and the electrician just needs to pull the new cables through and between the boxes with no agro - but we can do everything else like the kitchen install and tiling before that happens. I know the zones, everything runs correctly vertically/horizontally from all sockets.
So my question is with the wall with the cooker/hob -
The wall is basically a run of a double socket (vertical run up to it from floor then horizontally to...) > dp switch for hood > hob is here (300mm gap to electrical stuff either side)> oven switch > hob switch > double socket (horizontal to the next wall). The radial (why bother with rings now) will run straight along that wall. Both the oven and hob switches I want to run a separate conduit from the fuseboard so they can support whatever is needed (up to a 32amp switch) - so those will come up in zone from the floor under each switch.
My question is around where they cross - I can't take the radial past those two 32amp switches in zone as going above or below those switches goes out of the safe zone. I could drop it down under the floor and bring it back up the other side but it's a bit of a faff to have a conduit run like that.
I don't think technically there is anything against running the radial through those two boxes (and they can happily be 47mm or more if needed) but I know many electricians dislike it. I could run it just over the box out of zone but it won't quite be 50mm under the finished surface so it has to have metal conduit protection and I believe from researching flexible metal conduit doesn't count - it has to be solid. Again not necessary an issue.... but I do want all my sockets and switches in align.
I don't have an electrician yet to do the final rewire so I'd like the best chance of not having people go - err no mate not liking that - and having to find someone who is happy with the conduit runs.
So great members of this forum - what would people recommend on the routing?
(and yeah conduit maybe overkill - but I'd rather do it now and make any future rewires dead simple and just a case of pulling it all through. Sure many people would disagree and say it's a waste but it's what is happening
