My point is that by far the largest source of power used is the dishwater and tumbledryer. 3kg of wet clothes takes the same amount of power to dry at 248V as it does at 230V, so there is no saving there, it will just take slightly longer at the lower volts. Likewise the dishwasher, which uses the power mainly to heat the water and dry the dishes afterwards. Again no savings to be made there.
The only obvious place for me to see savings would be on the lighting, which is not enough to justify the outlay for an optimiser.
Now on the other hand, if I was to hook up a miniature pelton turbine to the mains water at home (no water meters where I am), I wonder how much that would generate
