Storage Heater with 4 wires | Page 2 | on ElectriciansForums
Discuss Storage Heater with 4 wires in the UK Electrical Forum area at ElectriciansForums.net
United kingdom
My mum bought some storage heaters with in built thermostat and I noticed there were 4 wires, live, neutral, earth and a black cable. I've wired storage heaters before and they didn't have this 4th black cable. How is this 4th cable wired? She has Economy 10 in the house is it possible to wire it direct from fused spur from an Economy 10 socket?
Thanks in advance.
Sorry Dave I'm typing on a tablet and far too lazy to be accurate and detailed in my posts.
Dimplex Duo heat uses a combination of storage and radiant panel.
Setback basically leaves the background storage heat as is and reduces the output from the panel.
Hi there. I had a wired dimplex radiator. I was redecorated and I want to replace with a socket but I have that black wires extra. My question is... Can I put a socket and what to do with the black wire? Thanks in advance
Reply to Storage Heater with 4 wires in the UK Electrical Forum area at ElectriciansForums.net
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
