Stranded Singles in Consumer Unit | on ElectriciansForums
Discuss Stranded Singles in Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Just a quick one, got a board change next week and am going to extend everything using an enclosure and din rail etc, normally i just use twin and earth to extend it all but this one as it buts right up against it I was thinking about using singles.
My question is, at what point would you start putting ferrules on the ends that go into the neutral and earth bars? I know stranded should be ferrules to stop it breaking apart but its not exactly fine stranded. I just dont feel it needed to ferrule the end of the 1.5mm as its not find stranded.
I personally cant see any problems with it, just wondered what other peoples views were. I have never used singles in this situation before, 2.5mm singles seems pretty solid, its just the 1.5 that im more bothered about.
I just thought it would be easier to use singles this time that's all.
Ill take some photos before and after when I have done it for you to see.
Thats what I was thinking, just wanted a bit of advice from a pro!
If it was fine stranded then definitely. It should look quite nice when its done, it 'Should' be a straight forward job as I checked it all out and it was all ok, so unless somethings springs from nowhere it will be a nice job to do.
Well if you aren't a Pro should you be changing a CU or is that a typo on your part?
Oh right, how are you doing today? I start back next week after 8 weeks on the sick and I aint looking forward to it, still some of the red stuff numbs the depression
you must be referring to that 'orrible creamflow that mike drinks. decent ale don't cause any problems. must admit, though, like a drop of colonial red.
Reply to Stranded Singles in Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
2 3
Recommended Sponsor News
Hi everyone,
