Strange Earthing Arrangement | Page 2 | on ElectriciansForums
Discuss Strange Earthing Arrangement in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
was told by Gary that the earth inside the head was paper thin and it would not disconnect with in the 0.4 sec
What does he base this one?
With a Ze of 0.18ohm you're laughing...
Isn't the head DNO property and therefore their problem?
Personally, unless he ''knows something'' we don't, he's talking out of his arse!! lol!! This DNO installation is one where PlLC has been used as the supply cable, and you couldn't by any stretch of the imagination say thats paper thin!! It's probably sweated onto the cast cut-out too, so unless there is a wooden fillet between the lead cable and cast box it's a sound solid earth!! Only way your going to check that, is by lifting a floorboard!!! lol!!
Reply to Strange Earthing Arrangement in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
