Strange Earthing Arrangement | Page 2 | on ElectriciansForums
Discuss Strange Earthing Arrangement in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
was told by Gary that the earth inside the head was paper thin and it would not disconnect with in the 0.4 sec
What does he base this one?
With a Ze of 0.18ohm you're laughing...
Isn't the head DNO property and therefore their problem?
Personally, unless he ''knows something'' we don't, he's talking out of his arse!! lol!! This DNO installation is one where PlLC has been used as the supply cable, and you couldn't by any stretch of the imagination say thats paper thin!! It's probably sweated onto the cast cut-out too, so unless there is a wooden fillet between the lead cable and cast box it's a sound solid earth!! Only way your going to check that, is by lifting a floorboard!!! lol!!
Reply to Strange Earthing Arrangement in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
2 3
