Strange RCD Fault | Page 4 | on ElectriciansForums
Discuss Strange RCD Fault in the UK Electrical Forum area at ElectriciansForums.net
G
Guest569
80amp main switch RCD, occasionally trips when a couple of circuits are switched on (doesn't matter which circuits) with nothing plugged in.
IR tests all good. Replaced RCD for new. Happens in all weather ( don't think its external )
Only sockets on this consumer unit.
Ive had my guys out at it twice with no joy. New build wiring from 16th edition.
Im going to investigate myself this week, Im sure Ive had loose connections causing tripping before, it about all I can think of, a loose tail somewhere around the main switch.
Anything else to look out for ?
Im pretty certain its not a dodgy nail at floorboard etc its fairly new property and in good condition with chipboard throughout.
Simple fault....lol. Plenty would be scratching there head at this one.
Just to clarify...I had a spark and a labourer at the job for 3 hours. I popped in for 1 hour with no test gear to check the obvious....I go back friday and armed with the correct gear I WILL find it..
This is all assuming my guys have done the procedures as they should have ....kinda hoping they have not
The customer has complete trust in me, so please concentrate on your own customer relations !
So...The wet leaf thing ....Would any procedures by the experts show this ?
Exactly. Far to many variables to solve over the internet....
I appreciate the advice but don't appreciate posts that assume I know nothing !
Typical of this forum though.
Jesus this forum is a joke.
Im more than experienced in domestic fault finding than most on here. Dealing with "council spec" rewires for over 10 years Ive seen it all.
If anyones actually cares to read my initial posts, we have been through the basic procedures and this is not a simple fault. Its guaranteed something bizarre....
Perhaps wind blowing a wet leafy tree on to a dodgy connection somewhere outside ? Just one example that could not be found by any procedure listed so far by the experts ...
Bizarre faults do happen, and I'm certain this one is a strange one ...hence title.
This forum is pretty pathetic, everyone far to quick to assume the OP hasn't got a clue !
You seem to have seen it all and know it all - so go fix it then. Daz
- - - Updated - - -
You keep moaning about this forum, but you keep coming back. Daz
Reply to Strange RCD Fault in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
I misread it.
