Strange relation resistance and Earth Around Sun 30 km/s motion | Page 13 | on ElectriciansForums
Discuss Strange relation resistance and Earth Around Sun 30 km/s motion in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
How cooperate above with gravitation ?
we have the same eqation for Gravitation and for Light
[ElectriciansForums.net] Strange relation resistance and Earth Around Sun 30 km/s motion
We must add information about constant motion to NEWTON and we no need use relativity
to describe how works GPS !!!
  • [ElectriciansForums.net] Strange relation resistance and Earth Around Sun 30 km/s motion
Motion can change GRavitation Intensity !!! BELOW VERY OLD LAW 400 Yearsold
GALLILEO NATURAL FALL DAWN LAW + INVERSE SQUARE LAW
m -----------Earth
M
Gallileo proved that mass M and m will natural fall down
in one and the same time
Marosz
m------h------Earth-----h------m >>> motion
Motion and Inverse Square Law ( gravitation )
mass m left and right will not fall down at one and the same time
HISTORY - SIMILAR PARAGRAPH RIGTH NOW WE HAVE IN BOOKS
PHYSICS
" Galileo postulated his relativity hypothesis: any two observers moving at constant speed and direction with respect to one another will obtain the same results for all mechanical experiments (it is understood that the apparatuses they use for these experiments move with them).
This idea has a very important consequence: velocity is not absolute. This means that velocity can only be measured in reference to some object(s), and that the result of this measurment changes if we decide to measure the velocity with respect to a diferent refernce point(s). Imagine an observer traveling inside a windowless spaceship moving away from the sun at constant velocity. Galileo asserted that there are no mechanical experiments that can be made inside the rocket that will tell the occupants that the rocket is moving .
The question ``are we moving'' has no meaning unless we specify a reference frame (are we moving with respect to that star'' is meaningful). This fact, formulated in the 1600's remains very true today and is one of the cornerstones of Einstein's theories of relativity
Marosz ( me )
MR GALLILEO GRAVITATION IS NOT MOVING WITH US ! WE CAN SOLVE YOUR PROBLEM
BY SIMPLE TEST
m---Eaarth---m >>> 30 km/s
stoper and
cornerstones of Einstein's theories of relativity ??:):):) PROBLEM NOT EXIST AFTER ABOVE POST !!!!
IF NOT EXIST PROBLEM WE NO NEED THEORY
WHERE IS FUTURE FOR MODERN PHYSICS ?
1 REPEAIR OLD PHYSICS !!!
2 MR MACH (I saw HIS DRAWING AND I LOST BRAIN )
before die he describe that AIRPLANE can Escape from SOUND ( supersonic 1,4 Mach speed )
MAROSZ after I saw Mach Idea I started
Airplane escape from sound what will be if mass m will escape from own gravitation ???
Gravitation = energy
Light = Energy
Motion = that signal is div by points where You were in past
p1...p2...p3...p4...p5...M ---- V ------>
Mass M is moving
p1,p2,p3,p4,p5 - points where mass M was in past
{p1--p2}={p4--p5} this condition describe constant velocity
From each new position mass M is sending gravitation's wave
( Yelow rings - below drawing explain three situation)
1 mass M speed = ZERO
2 mass M speed = grawitation's wave speed
3 mass M speed > G
How compare light and gravitation ?
Proffesional photographer use ( FORCE of LIGHT definition )
Newton use Force of gravitation
If rocket Accelerate accelerate ... accelerate
gravitation forces between Rocket M and person m going down
down down Mass m not feel distance L but L+Lx
for distance L gravitation need time T
during time T mass m and rocket escape Lx distance
What is starnge in my post ?
nothing all is very natural !!!
" I made all alone in my home without miliondolars for test !!!" only this is strange
PEOPLE WHO LEARNING US PHYSICS ARE TOTALY FAR AWAY FROM REAL WORLD
THEY PRAPARE DRAWING very easy is make line on paper but look below in real world not exist
line but many lines
LASER's frequency = 120 000 000 Hz
LASER is INSIDE ROCKET and MOVING IN SPACE ?
Fact 1
Between each line exist distans 1/120 000 000 sec
Fact 2
Each red line ( below picture ) represent axis
( the beam has got 3D shape next picure Inverse Square Law special if You are using cheap laser in home and not controle temperature )
Fact 3
Each Rocket is moving respect to point in space
where laser was in Past (with rocket) and where
laser started signal ( energy pack)
During time T light made distance "a" how many meters made rocket?
NVERSE SQUARE LAW - old Greece
More far from place
where the signal started = lower intensity of signal
( "lower brightness for Light that we registerin" )
1R = X , 2R = X/4 , 3R = X/9
X- brightness, R- radius ( distance )
the same energy portion but different area
WE ARE ON THE EARTH EARTH IS MOVING IN THE UNIVERSE NOT RESPECT TO
STARS BUT RESPECT TO POINTS OF SPACE WHERE EARTH WAS IN PAST
p1..p2..p3..p4..p5...EARTH >>>motion
Aye, that's fine but how the hell does all this help the Artful Bodger cure his RCD that's been tripping without reason ever since he replaced the CU or DIY Dave to wire his shed via a spur from the spur feom his outside light which is itself a spur from the bathroom fan spurred from the shower??
THESE are the things we as simple but hard working electricians need to know ....... NOT what is the Square Root of Infinity!!
Get a grip man - you're not even on the same page!!
Hi Maciej,
It seems to me, the success of your designs will depend upon your tools for measurements, which aren't advanced enough to describe and predict your designs behaviour. You are therefore forced to project your own ignorance into the math equations, giving the illusion that the equation actually represents the phenomenon it's trying to describe. In reality, the equations just represent your current degree of accuracy given your limited tools for measurement. Try and get your hands on a thermal quantum scanner with 16TB singularity processor. You'll be glad you have it the next time your inertial nullifier drive conks out halfway between here and the Boomerang Nebula (I hate it when that happens). Although, I find giving it a good smack with my titanium crowbar gets the drive running again. Just remember, everything is deterministic, thus try not to throw our established paradigms of reality into uproar. Live long and prosper! Nanu Nanu! :biggrin:
Hi Maciej,
You was on a roll then Kam' but sorry to point out you made a school boy error as you forgot to bring into the factor the dilithium Crystal anti-matter reactor and the concept of an anti matter breach may create a mini blackhole as the instant annihilation of the mass causes a pinching effect on space/time as it shifts to pure energy and a minute gravitational ripple is made.... but of cause ill stand corrected if your star-ship is the old NASA3000 20 Port fluted fusion core system (yes its old hat, but just covering all bases) as this would hold your statement fully correct.
I think we all need a trip over to Wroclaw, where I believe he's from, and discuss his theories in depth, with the man himself, in the numerous good bars I discovered there once! :)
I got to hand it to you my little jedi master. You know your core systems well. The NASA3000 20 wasn’t my 1[SUP]st[/SUP] choice propulsion system, it’s a bit temperamental but it works. I started out with a flux capacitor which worked well, after a few teething problems I was having with the radiation shielding, which telectrix helped me with. But it was such a ball-ache having to wait for a lightning strike every time I wanted to go somewhere. And then they were like buses and two or three would strike around the same time. So I went for something more reliable.
Now, because from what I can see so far, Maciej has created his very own paradox by coming onto an electricians forum. Electricians are sceptics and analyser. Scepticism is the basis for science. As such, scepticism is absolutely crucial in order to discover the truth. Now it’s true that far too many people are gullible, rather than sceptical. This gullibility has led to the following of some dangerous ideologies that make people little more than mindless sheep. Believing in limited depictions without thorough investigations is not healthy. But hardcore scepticism that reduces the cosmos to nothing but mechanical matter and third-dimensional mundane mediocrity is not necessarily healthy either. In this sense, the gullible and the sceptic are in the same boat, and the paradox thus presented is at the core of the quest for understanding the workings of the universe. Much of the time, the materialistic life we lead rings true, as the quantum nature of the universe does not factor into our daily live. But that’s because we can’t comprehend the stubbornly persistent illusion. Archy is right you know, we need to nip across to Wroclaw for a little jolly. Once we grokked our heads together with Maciej and sorted through the scientific anomalies of classical and quantum mechanics. Then moved through Plato's cave into the realms of rampant mereological nihilism. If after all that he’s still desperate to build a little rocket and some weapons of mass destruction, I will give him a hand with some legos and some torches.
And on a more helpful note. Dennis Tito had the bright idea to privately finance spaceflight but had to knock the idea on the head, after it became apparent that it just wasn’t doable without the assistance from NASA. So Maciej is really going struggle with the 50p that we on the forum will be able to chip together. :biggrinjester:
Ive got a Gravity Drive up for grabs and a unique one off system with only one previous owner, it was key warp engine for the Event Horizon and I claimed salvage rights to that field of space so Im up for offers if anyone interested --- Oh forgot to mention you have to collect your self and please be genuine the last 2 customers seemed to have vanished without collecting or paying --Damn rude!
Reply to Strange relation resistance and Earth Around Sun 30 km/s motion in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
