Stripping SWA - any quick methods | on ElectriciansForums
Discuss Stripping SWA - any quick methods in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
iv got a large amount of 4 core 10mm SWA to Weigh in.
Iv never took copper to a waste site before to get weighed in.
Few questions
Do they take the steel armouring too?
Is it actually worth stripping?
Has anyone used brownhills before?
Is there any quick ways to strip? It's took me ages to strip about 60 metres
So, that weighs 998 grams per metre.
40mm² * 1000mm * density of copper per mm cubed = 358 grams per metre of copper
If you bin the steel, PVC and PE, you just threw away 64% of it's weight.
  • So, if the scrap dealer is only paying double for bright copper/kg vs the SWA/kg as is, you just lost money by stripping it.
  • If the dealer is paying 2.77 times, it's a tie, but you just wasted an awful lot of time/effort and now have a load of cr@p to get rid of.
  • If they are paying triple, you gained 8% by stripping it, but was it really worth all the effort and rubbish you've now got to dispose of?
The steel is practically worthless in that sort of quantity and not worth calculating.
Moral of the story - Don't bother stripping scrap cable!!!!!
The scrap dealers around here pay around 40% of bright for PVC insulated and around 20% of bright for armoured.
So five times the value for stripping it would be worth it, because you'll add 80% (5/2.77 in this case) value to what you already had. Still seems like a lot of effort though, depends on how quickly/efficiently you can strip it I guess.
Pete I have no use for it at the moment and I just don't have any room to store it
Can you not sell it as a going item? I mean 60M of 10mm4c must be worth more as an installation item, than spend hours scrapping it, I can understand the storage problems, but someone must have a use for that amount of cable. If you are that sure tou want to get rid of it, see how much a scrap dealer will give you as is.
Reply to Stripping SWA - any quick methods in the UK Electrical Forum area at ElectriciansForums.net
