R
rt1200
Please see attached pdf guidance note relating to the structural assessment of roofs prior to fitting PV arrays and the requirement for Building Control Appproval, if you are not registered as a competent person/body in the CPS scheme. MSC is not CPS. I hope you will find this useful as it is fact and not just someones opinion!
In summary many if not most PV arrays will require a structural assessment of the existing roof, or the proposed new roof to ascertain that if it can safely take the loadings. Many local building control officers are struggling to come to terms with what this means and its implications. They are not competent themselves and will/should ask for a structural engineers report. Some appear to be confused and talk only of the electrical installation. Nevertheless, as you will see in the attachment, it does relate to structural stability. Under the CPS scheme a competent person would virtually have to be a structural engineer to properly assess.
The bottom line is that a structural engineer is required whether you are CPS or apply for Building control approval via a building notice. Incidentally, the cost of the LA approval is related to the work itself. NOT ALL the work - just that related to strengthening the roof, so in most circumstances it shouldnt be hundreds of pounds. View attachment 6798View attachment 6798
