First post and ready to deal with the onslaught from angry electricians
There's still plenty of money to be made in PAT testing and it is possible to make a significant income from selling at 60-70p an appliance but it's got to be approached in the right way.
First and foremost it's possible to do an average of 300 appliances a day per 8 hour shift. Sometimes a PAT tester will do less and sometimes they will do more depending on the environment.
I think the problem that a lot of people find with PAT testing is that they don't approach it with efficiency in mind. I don't mean that any of you chaps who disagree with me on the above are in any way inefficient but to make PAT testing pay you need a hyper-efficient set up in order to maximise the total number of tests a person can do. Like with sales it's a numbers game but it's a numbers game with the proviso that the engineer actually does the job properly!
So, in terms of set up I supply work to firms where their engineers are equipped with smart phones and Seaward Primetest 300's. The testers are tethered to the smart phones and the smart phones are running bespoke software. Once testing is completed the engineer signs off the job, the tester downloads the results to the smart phone and the smart phone uploads the report in it's entirety to a laptop, be this by plugging the smart phone in or through GPRS remotely.
As soon as the engineer completes the work the software automatically creates a report and invoice. There's no need for data entry or paperwork; the software does it all for you and then it's just a case of emailing the client the report.
As some of you quite rightly point out the difficulty in being a PAT tester is sourcing sufficient work. 60p - 70p a test may be a very cheap rate but it's impossible to survive on PAT testing if you're picking up only a 100 tests a week or some such. In order to be able to have a successful business in just PAT testing you need huge volumes of work in order to generate a consistent return.
If you're averaging 300 tests a day, every day, then you're looking at an average of 6000 tests a month, if you don't work early and stay late or work weekends. 6000 tests gives one engineer a turnover of between ÂŁ3600 and ÂŁ4200 a month minus expenses.
But then if you employ a commission only sales rep' (that would be me!) then you have no outlay for sales until you're actually provided with sales, at which point you pay AFTER the work has been completed.
So, a marriage of technology and high volume sales makes PAT testing very profitable.
I get what people say about how many tests you can do an hour but most IT equipment these days have molded plug tops so there's no need to take the plugs apart, the Seaward Primetest 300 is pre-programmed with a suite of tests for various types of appliance and the longest set of tests takes between 15-20 seconds to perform (according to Seaward's technical department). 20 seconds is a long time if you're sat waiting for it to pass. When you're using software designed for PAT testing and optimised around the PAT testing process (think test numbers automatically increasing by one, drop down menus with a favourites list for the most popular test items (VDU/CPU/IEC Lead/Extension Lead/Kettle etc) automatic generation of item locations, barcode scanners for retests) this is more than enough time to record the test data for that appliance. As the tester is battery powered and you're working from a smart-phone you can test numerous pc's whilst under a desk and so it is possible to pick up 300 appliances a day if engineers apply themselves.
The standard rate for a PAT testing engineer as an employee these days is between 25p and 35p and with minimum's to be hit before bonus is paid. A one man band selling at 60p an appliance with an employee being paid 30p an appliance and who accompanies his boss to every job i.e. the same vehicle so no extra cost for fuel means that the boss is actually earning 90p an appliance.
I'm genuinely interested in only working with firms that demonstrably do the work properly and have stopped working with several firms because they're not up to scratch. I understand how electricians dislike PAT testing because it's VERY boring, more labour intensive than being an electrician, less well paid and how you hate competing against people like me who consistently undercut you on price but all I would say is that just because a firm can significantly undercut you does not always mean that they're not doing the job properly (and believe me I agree that there is a significant amount of firms out there who aren't doing the job properly!). The latest scam I've seen is companies saying they work in line with the IEE recommendations, quoting low to be competitive then going in and doing a visual check on every piece of IT, knowing that if they're pulled up on it they can hide behind the IEE frequency recommendations.
