I have installed 2 garage sub mains and not sure how the certificate and testing should be laid out.
First Sub main in garage on 80a RCD with 16a circuit for sockets and second 6a for lights. The board is fed by 4mm swa from 32a on house board. House is TT and seperate rod at garage to make that TT.
Question is on the installation cert for the submain, what goes in characteristics of primary supply device - main cut out fuse or 32a mcb and main switch supply conductors - main 25mm at house board or the 4mm swa at sub main. Or should both be tested and cert'd
